1980 Evinrude 7.5 Part name?
shaw499
The above mentioned motor has a broken part. It is a little plastic piece with a roller on it. A flathead screw runs through the plastic just below the roller and screws into the carb. The roller rest against a part of the throttle underneath the flywheel. As you throttle the part under the carb rotates pushing the roller and mystery part forward opening the second butterfly valve on the carb. Does anyone know the name, part number, where to find it?<br /><br />thank you,<br /><br />jim
Bear
Re: 1980 Evinrude 7.5 Part name?
Parts <br /><br />I hope you'll find it there.<br /><br />Good luck!
wayne h
Master Chief Petty Officer
i think you are taking about the "cam follower" it rides on the throttle lever and the cam on the points plate.when you give it throttle the plate turns and the cam follower rides on the cam and works the throttle lever on the carb. i dont have a part # for that engine but my 9.5 rude uses the kinda setup
OBJ
Hi shaw...<br /><br />This is the cam follower lever and roller.<br /><br />Lever part number is 323327<br />Roller is 323328<br /><br />The roller should just pop of the lever. If it's in good shape with no groovers in it, it can be reused. Also the allen head screw can be reused out of the old one.<br /><br />These can be gotten at your local Johnny/Rude dealer.
Hooty
Here in Texas, we call it " ah lil' plastic chingaso", but I think Wayne34609 has it right. Sounds like the cam follower.<br /><br />c/6<br /><br />Hooty
BHM7952
This is a cam follower #323327. We have sold out of this part but I have an original parts catalog for this engine that gives an exploded view of each component along with the part name and order number. $7.50 mailed to you. For more info email:<br />linda@nu-z.net
