chunkytrout
Thread starter- Joined
- May 9, 2003
- 39
OK, here we go...First, motor came with the boat so I'm doing my best not to throw it in the lake. Started having problems at low rpms early this season then while running WOT a couple of weeks ago she just lost a cylinder. Compression checked out but after I got home I realized the batt was dead. Marine mech said "You have to have one hell of a batttery for that motor to run right". OK, new battery. Put the muffs on in the back yard and one of the mechs (I live across the street from a marine shop) came over. She fired right up on all three. Tested the rectifier and it was good. He adjusted the low idle a bit. "Should be good to go." Took her out to the lake last night and fired right up but then died while warming up. Couldn't get her to fire for a while then it started so off we go. Lacking on power I knew something was still wrong. After I shut her down, she'd start again but die as soon as I put her in gear. Plugs and wires are good. Gas is new. What now? I've heard from more than one mech that this motor is a pain.
