pulses/rev
supergenius74
How many pulses per rev should my tach be set for for my 1975 johnson 135 V4 ? Its set on 6 now and I think that may be wrong. TIA
Dhadley
Re: pulses/rev
If its an E/J tach the correct position is 6.<br /><br />Good luck!
Moving Target
Re: pulses/rev
6? A 4 cylinder engine would have 4 pulses per revolution right? or am I missing someting?
Dhadley
Re: pulses/rev
The tach reads the alternator side of the stator rather than the ignition side.<br /><br />Good luck!
gaugeguy
Re: pulses/rev
dhadley is correct. The engine has a 12 pole alternator, and counts 6 pulses per rev.
supergenius74
Re: pulses/rev
im not sure if its a E/J tach it doesn't have any brand name on it but i can post some pics if that would help. It has a little round twisting dial on the back that has the lable pul/rev next to it and that is it. it was set on 6 when i got it and am doing some re-wiring right now and have all the gauges out of the boat. Are you saying that because of the type of stator on it that it should be set on a 6 pulse setting? Thanks for all the help guys.
