yooperdawg
Thread starter- Joined
- May 11, 2003
- 9
the new old boat is a 69 55hp johnson. told my son to change the lube in the lower unit, filled it with heavy marine gear lube, i believe . after two days of trolling( +/- 12 hours) we have milky gear lube oozing from the weep holes. no we didn't change the seals on the fill and vent screws (tomorrow i will, along with the lube) after searching this sight for like problems i found out we should have used a lighter type of lube because( i think) this engine has the hydro electric shift. could it be that we haven't taken years off the units life? hopefully the seals will do the trick. but i am concerned about thick lube causing damage in a system meant for thin lube. so how bad did we goof up? thanks folks for the help.
