buttonhook
Thread starter- Joined
- May 4, 2003
- 129
I know it has been covered alot but. I'm going to raise my motor today and this is not a easy undertaking. drilling new holes etc. and I'm wanting to get it as close as possible the first time. (background info) 15'-16' fiberglass tri-hull with a flat bottom at the stern. 4" of set back, 1988 20" shaft 28 hp spl johnson, stingray hydofoil, 9.25 X 12 alum prop(could change prop), no power tilt or trim. I know that I could move it to the bottom of the hull but with the set back do I need to move it up more? And what is the gear ratio of this motor?(trying to figure my prop slip)<br />5000 rpm sweet spot and 19-21 mph on the speedo.<br />it seems it should not have that much slip and if I changed the motor height and prop pitch would it slip less.<br />Sorry for this long post. it is the first boat I've even owned and the former owner though he was McGyever! I'm just wanting to get it right the first time.
