Reg/Rect replacement 94 Johnson 200hp
Reelistic
While in the process of troubleshooting the charging system, I removed the power pack to get access to the stator wires to check continuity. All was well there, but I appeared to be within minutes of being able to remove the entire Reg/Rect. Is the replacement of the Reg/Rect that simple? I received a quote of $170 labor to replace the Reg/Rect which makes me wonder if I'm missing something?
clanton
Re: Reg/Rect replacement 94 Johnson 200hp
4 steps to remove. Disconnect battery, remove power pack, swing power pack bracket to side to expose regulator, remove regulator red lead from solenoid, remove the 6 screws and regulator.
Reelistic
Thanks clanton for the quick response... just removed the old reg/rect (about 30 mins), will be looking for new part now. Thanks again.<br />p.s. also Ret AF
