At high speed, feels like I hit something in water
mountainboy
Hello everyone, Johnson 20 1978 model# 20cr78c--took it out today and it runs strong. Not all of the time but twice at high speed I heard a "clunk" coming from the outboard and it felt like I hit something with the boat. What motor problem could I have? By the way, I checked my l/u fluid again after I got home and I do have a seal leak. Something to be working on the next few days. Thanks
steelespike
Re: At high speed, feels like I hit something in water
Your clunk is probably a worn clutch dog.<br /> Check the dog and gears when you do your<br />seals.I dont know your motor but on some motors<br />the shift can be adjusted.
Yepblaze
Yea, what he said.
mountainboy
Thanks a whole lot!!!
Hooty
Check and see if you've got any metal particules in the l/u lube when you drain it.<br /><br />c/6<br /><br />Hooty
mountainboy
I went through my manual, the shifter did not need adjustment. It was fine as is. Checked out lower unit lube and no metal particles. I'm guessing that even though there are not metal particles the clutch dog is still worn. I'll keep you guys informed. Thanks again
sparkroost
Could it be the prop(the rubber bushing)?
mountainboy
Not sure about it being the prop's rubber bushing. I'm going to start working on it the next couple days and will find out. I guess that is one of the benefits of having 2 outboards, while one is being worked on the other is available for fishing. :D
