Guidance on 15 hp Evinrude E15BLCNC
Bobby D.
I removed the powerhead from the housing because it wasn't peeing from the pee hole and was getting very hot and I tried all the recommended cures too no avail ie: new water pump, back flush through the pee hole and a garden hose into the copper tube. I found that the grommet at the end of the copper tube was obstructing the flow.While I have this disassembled is there anything else I should look at? Thank you
NathanY
Re: Guidance on 15 hp Evinrude E15BLCNC
You will definately need a new gasket for that( I think it is called a baffle? or something like that), also just for the heck of it, you might clean all the carbon build up on that under side off real good.
OBJ
Hey dude, didn't hear ya' mention replacing the thermostat. Ya' did do that didn't ya'. :confused: :confused:
Bobby D.
Hi OBJ, Thanks, but I did remove the thermo.
D
DJ
Guest
Dude,<br /><br />I think you found your problem with the swelled grommet.<br /><br />You DO need that thermostat for proper engine operation.
