FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Hi Poolshark<br /> The prop nut, Part# 376501 is a dealer part. They don't list a size. There were three prop choices. #383629 9"X10"std.<br /> #379717 9"x9"<br /> #592959 9"x10" weedless.
thanks alcan did help....<br /><br />we have a couple af marine shops about an hour away..will check with them on that part no....<br /><br />i have a prop that was given to me that will fit (come off evinrude same year/hp) but dont know size or pitch...how do you tell??<br /><br />i have a 14' PolarCraft with a front deck that i extended ~2ft with 1/2" plyboard and a rear bench with a TohoRig(from cabela/bass pro) livewell..dont really care 200mph with hair on fire but dont want to be grandpa on a sunday poke around...i fish delta oxbows mainly..what size would you recommend...
left info out in last reply..<br /><br />rear bench and a tohorig livewell that is pretty well centered in boat...boat moves real good with a 36lbs thrust trolling motor..
Poolshark,<br />I would go with the 9" X 10" Prop, which is rated for a "Normal" load for your sized boat . This should put you in the ballpark as far as WOT RPM's.<br /><br />Does the Prop you have, have any numbers or letters on the hub??
not sure..will check on it tomarrow...<br /><br />do you preferr pin-drive or spline-drive props....i have a foot from a parts motor that have spline drive but prop is spun out...
