Greg Holmes
Thread starter- Joined
- Jan 4, 2003
- 14
Hi to everone. I am a bit new to this so bear with me. I have just purchased a 14'6" boat with an Evinrude 70hp on it. Model AE70TLCOC s/no: A0310488. I have no info. on it and know very little about it so an operator/service manual would be very helpful. I am told it is a 1989 model. Perhaps someone can verify that for me?<br />Also what is VRO injecion? I have some service history but not much.<br />It seems to start and run well but has 2 problems.<br />1. When engaging gear it stalls if you are not quick enough on the throttle after disengaging the cold start.<br />2. A high temperature alarm sounds after running in excess of 4000rpm for 5+ minutes. If you go back to 1500rpm for a few minutes it stops. If you keep under 4000rpm the alarm does not sound.<br />Any other maintenance / troubleshoting info. will be gratefully accepted.
