FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
no water out of head on evinrude mod.4447 s/n 91184 5 hp. pump is working and when i hook up a hose to the flush fitting still no water comming out thanks
4447 Evinrude <br />Year 1952 <br />7.5HP @ 4000 rpm<br />12.4 cu.in. = 203.2 ccm <br />2 cyl <br />47 lbs. = 21.3 Kg <br />Prop 8 x 8 , 2 blade <br />Gear ratio 13:20 <br /> #4447 1952 7.5 hp Evinrude picture <br /><br />There is a tube from the lower unit to the powerhead, right?. I think it isn't in the right position at the powerhead. Do you have a manual?
I don't believe there's supposed to be any water coming from the head (tell tale) on that motor. Does it overheat? If not, don't worry about it.<br />Backlash
hi guies thanks for the hels droped the lower unit. water pump and plate is ok. don't see a copper tube. -thanks bear- no manual oldest one i can find is 1956. any ideas where to look for this manual doug
D T, I was on ebay the other day.Put in outboard manual. Something like 30 pages came up maybe your manual is there somewhere.<br /> Also www.kencook.com does reprints of manuals.
