Evinrude Sportwin
Dave Berndt
I'm looking for information on an Evinrude Sportwin outboard motor, the only number I could find was on the side, 4423-11014. I dont know the horsepower or how old it is. It's a 2-cylinder motor. The gas tank goes around the flywheel. Can you help me?
Bear
Re: Evinrude Sportwin
Hi Papa!<br /><br />#4423 <br />Evinrude 1951 (same model number 1947-51)<br />3.3HP @ 4000 rpm<br />6.2 cu.in. = 101.6 ccm <br />2 cyl <br />39 lbs. = 17.7 Kg <br />Prop 6 7/8 x 4 3/4 , 2 blade <br />gear ratio 13:18<br /><br />A picture:<br />1951 3.3HP <br /><br /> :)
Dave Berndt
To Bear:<br /><br />Thank you for responding so quickly. This is my first visit to iboats, and I'm not sure if I'm doing this replying to your answer correctly. :confused: My friend has this motor, it's in pieces. He'd like to sell it to me for $50.00. Is there a manual available and can I still get parts for this motor?
plywoody
Bear,<br /><br />Now you have me all nostalgic. When I was a kid, I had a motor just exactly like that. I would not have a clue how many hours I had on it, but I would use it to float firewood rafts (used to tack logs together and run her a few miles against the current. Had to row as hard as I could with the engine going full speed to make any headway!), and fishing, and generally every chance I had, for years and years and years, all in salt water.<br />Never did anything to the motor, and it still runs just fine. My little brother has it in Idaho, and fool that I am, told him he could keep it over there.<br /><br />I am sure you can get parts, but we always used to fix little things with anything we could figure out that would work.<br /><br />If you don't want to buy it, let me know. I will.<br /><br />(jwalsh@tdn.com)
Dave Berndt
plywoody- Thanks for your response also. It sounds like you have alot of good memories. I've sent you an e-mail. I already have the motor. I just need to know if I can get repair manuals or order parts. Thanks again
Dave Berndt
djohns19: Thanks for the info. I found the website and sent an e-mail... I'm surprised at how many responses I'm getting here. This is a really good site. I'll let you know how I do. Thanks again.
