DOH! Crossed battery connection on 87 evinrude
Wkoch
Well... Went to hook my battey back up so I could winterize. Let my father do the connection while I filled a garbage can full of water to put motor in. ( only a '87 28hp Evinrude SPL). he put the positive on the negative terminal on the battery and then went to put the negative on the positive side. Once the connection was made I head sizzling from the head. Looked up after I bumped my head and saw smoke coming from the head. He immediately removed the connection once he saw the smoke and heard the sizzling. <br />As you can imagine this made me nervous. I made the right connection and she fired right up.<br /><br />Do you think I will have any problems down the road/river?
miloman
Re: DOH! Crossed battery connection on 87 evinrude
did your motor start and work properly if so don't worry about it
D
DJ
Guest
Wkoch,<br /><br />If your engine also has a battery charging capability, you surely cooked the rectifier. It only takes a second.
Raroo
Mine always sparks at the battery when I do that.<br /><br />Jet Whale
sloopy
I take it you do that alot?
Trent
Like Djohns said...It only takes a second. Check to make sure the charging system is working. (If not replace the rectifier).
Wkoch
How does one check to see if it has the battery charger capability?<br /><br />Have no clue.<br /><br />Wkoch
Beaux
should have 12.5-14.5 volts across battery terminals when motor is running.
