1990 Evinrude 150 HP V6 Ignition Wiring Diagram
Rampart
Can anyone help me with a diagram for a 90 Evindrude 150 HP V6. I Bought a new switch and I have to pull the kill switch to stop the motor. The key does not kill the motor.<br /><br />Help!!!
clanton
Re: 1990 Evinrude 150 HP V6 Ignition Wiring Diagram
A termial, purple wire<br /> B termial, red wire, may have purple stripe<br /> C termial, purple with white stripe<br /> S termial, yellow with red stripe<br /> M termial, black yellow stripe<br /> M termial, black this termial is a little taller then the other M termial.<br /><br /> This dont match bump back to top.
Rampart
Thank you very much. I am having a problem with my Trim Guage. I am not sure if the wires are on properly.<br /><br />Would you happen to know about those?<br /><br />There are 2 wires comming out of the Trim Harness at Red and a black. They both have a strip. I can not remember what color.<br /><br />There is an igition wire that is only hot when the key is turned on and a ground.
clanton
The t/t gage may have 3 termials , G termial ground black wire, I termial power hot wire when key in on. S sensor can remember color, but should be the wire that runs beside the black wire, that you said was red and had a stripe.
