Re: 2000 Johnson 150 Oceanpro - VRO Pump?
Thanks for the responses... Here's a little more info. Yes, the warning buzzer does come on for a few seconds when the oil warning light comes on, again this only happens when the boat is underway and at higher speeds. It never happens at idle. I purchased this boat & motor new in March of 2000 from a local dealer. I haven't ran it much, it has less than 30 hours on it. The gas is fresh but I guess it could have some water in it causing it to run rough. I've checked the plugs and compression, both are fine. My concern is the oil light/warning buzzer that comes on... my first thought was the VRO pump as I've heard many stories about them failing and ruining an engine.
