anthony@woodprojects.com
Thread starter- Joined
- Sep 2, 2002
- 3
Critical Stats : 1995 112 HP Evinrude, purchased used 4 weeks ago.<br /><br />So I start changing my lower unit gear oil and notice the color is brown... like chocolate pudding but thinner. I drained it, pumped in new, ran it with water muffs for 20 minutes, checked and it looked creamy. So I drained it again, refilled, put the muffs back on and ran for another 10 minutes, same creamy oil.<br /><br />So I called the repair shop this morning because I thought I had a bad seal and he wasn't so sure. He said several of the newer (and cheaper) oils turn milky when they are frothed. His reason for believing this was because I didn't submerge the lower unit after changing the oil. He said the water never had a chance to mix...<br /><br />He suggested I take it on the water a few hours and then let it sit. He said if the seals are actually bad, I should see a little water first... but not to be alarmed by the creamy color of the oil.<br /><br />Opinions?
