70 Johnson still seems to bog down
Chacer
I have replaced fuel line, primer bulb...there is no line on/in the prop...seems to go fine at WOT the first few times then bogs down......help!....thanks guys, this forum is the best...
BKool68
Re: 70 Johnson still seems to bog down
I would suspect some debris floating in the carb bowls. Pull the carbs and remove the bowls. Empty into a clear glass or jar and see what it looks like. If it doesn't look clean that is your problem.
Chacer
Thanks...will do in AM....in a sick way; looking forward to it... :)
rlouns
I had a similar problem on a 90 HP Force - it turned out to be a broken wire on the #2 Coil<br />it would hit and miss depending on when the wire touched. I could not find it until the wire vibrated out of the rubber boot at the connector. ;)
