Looking for PVC drain (see pic)
BRG25
Anyone know where I can find this drain? It came out of the livewell in my boat (sprung a pin hole leak). Approx 1" diameter.<br /><br />Is there a reliable way to patch the hole? PVC glue? It was a pain to get out and I only want to do it once.<br /><br />Thanks,<br />Brian<br /><br />
Osprey
Re: Looking for PVC drain (see pic)
Had to laugh when I read your post. I just finished doing one of these today and have the bruses on my arm to prove it. Told the guy at West Marine "I only want to do this once".<br /><br />This is a standard style marine drain fitting. Most any marine supply store should have one. The one I purchased from West Marine has a design improvement that helps installation. In addition to the backing nut, the flange on the drain end threads on/off as well. So the complete unit can be tightened down from either side of the drain.<br /><br />Be sure to use plenty of silicone and replace the hose-clamps as well.
Osprey
PS Don't try to patch/reuse this fitting. It's likely getting brittle as all the plastic / pvc ones do over time. If you search around a bit you likely can find one made out of bronze.
BRG25
Thanks, any idea which hose size I need? The OD of the insert on the drain is 1-1/8" iBoats list 3/4" or 5/8" hose size?<br /><br />Thanks,<br />Brian
Osprey
These fittings are sized based on the ID of the hose they connect to. If the OD of the hose flange on your fitting is a little over an inch then this sounds like a 1" fitting ment for use with 1" ID hose.<br /><br />If the thru-hull fitting for this drain is at or below the water line, its a good idea to use two hose clamps on each end.
