looking for a new propeller
hunter_80
i have a evinrude that have a 9.5x10 pich looking for a new or a good used one i think the year of the motor is 72 or 73 model# is 90593c and the sn# e03691 if you have any info you can e-mail at hunter_80@hotmail.com
suzukidave
Re: looking for a new propeller
It's a 90hp Evinrude with a 9.5x10inch prop?!? Either you run it on a barge or some of those numbers are wrong. Could it be a 9hp?
MGuckin
It is a 1965.<br />Propeller Type: Outboard<br />Manufacturer : EVINRUDE, JOHNSON<br />HP / Model : 90 HP V-4 - PIN DRIVE<br />Year : 1960-68<br />Boat Size : 17'-19' BOATS SKIBOATS<br />Material : ALUMINUM<br />Blades Diameter & Pitch Rotation Part number Style Comments <br />3 10-1/4 X 10 RH 012043 MICHIGAN MATCH <br />Be aware that some have had installation problems with props from this company requiring special shims and washers.
hunter_80
no its a 90 hp 1965 model<br />and its has on it right now a 9.5x10 prop from<br />michigan thats what it has on it when i traded<br />for it.
suzukidave
Wow, what a tiny prop for a 90hp. MG what is the gear ratio on that thing ??
dymo
Sounds rather small to me also. I have a Chrysler 70hp with a 13 X 17 prop.
