After searching and reading some older post I think you may be able to point me in the right direction on props. I don't want to start dropping money on just any prop. I have an 85 Charger with an 85 Johnson 150. Fully loaded will run 5500-5600 with a damaged (1 blade) factory OMC SS prop. I would like to increase top end performance, hole shots are not a question now, jumps right up. any recommendations? (raker, turbo, speed zone ect.) Also where should the engine height on this rig be set at? Right now I can run fully trimmed and could use more. Thanks for yours or anyones help.
