FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 20 horsepower Johnson Seahorse (model# 20CR79R serial#C8054451). It is very hard to start and when it does it won't idle. It runs fine at full rpm although it does seem a bit sluggish. Also, what year would this motot be?<br />Thanks
don't what year it is but you could have a couple of problems. When it is running does your primer bulb go soft? Have you cleaned/rebuilt your carb? Sounds like you have some gunk in your high speed jet or you have dropped a cylinder. Check for spark at idle. Pull a plug wire and see if it changes anything. Then replace and pull the other. What happens? If one does not change your running the ignition coil to that plug is probably bad.
alexd... sounds more like low speed mixture adj to me... just had my 18hp evinrude apart before the big weekend... and took some time to get the low speed mixutre screw tuned in. Until then it also was hard to start and keep running at low speed. Now starts on 2/3 pulls and idles ok.... jim
Spark is good to both cylinders and I had a mechanic clean the carb last week. After running for a couple of minutes you can give the primer bulb 1 or 2 squeezes. I'll try a compression test and see what it says.<br />Thanks!
I'm with jbutter on this one, sounds like your low speed circuit may be dirty still. Does you motor have an inline fuel filter? If not install one between the pump and the carb and clean the carb out again.
