Pro Crappie Guide
Thread starter- Joined
- May 6, 2002
- 32
I have a 1996 50 hp Johnson 3 cylinder oil injected..<br /><br />I was having a problem with it suddenly stalling out at 3/4 throttle and above 3 months ago. I replaced the power pack, and everything was fine.<br /><br />It did it again today though, like it loses power and slowly runs out of gas and then suddenly stalls...Upon restart it seemed to be vapor locked, as the starter wouldnt turn over the motor. I had to spin the flywheel with my hands to loosen it up.<br /><br />Then when it started it was only running on 2 cylinders...But not in the SLOW mode, because upon holding the throttle wide open in gear for a certain period, it will slowly bog its way up, well over 2500 RPM's....But still running rough and on two cyclinders on the low end...What would cause this and for it to stall suddenly at WOT...and to seemingly vapor lock like that?<br /><br />I have replaced the fuel line and fuel filter already also when I changed the power pack.<br /><br />thanks for your help,<br /><br />jeff
