used block for johnson or evinrude 115 (1978)
Rob DeHaven
i am in need of a used block for a 1978 johnson or evinrude 115. it is a johnson seahorse mag flash cd. i have emailed several businesses but was hoping someone out there might have one for sell a little cheaper. any info would be great.<br /><br />thanks
Dhadley
Re: used block for johnson or evinrude 115 (1978)
All V4 crossflows from 1978 on will bolt up. Are you looking for a block only or a powerhead (less carbs and electronics) or a complete dressed powerhead?<br /><br />Good luck!
Bob_VT
Check e-bay I saw one on there last night. It was a stripped block.<br /><br />Bob
Rob DeHaven
yes i am looking for just a stripped block.<br /><br />Bob-VT, what do i go under on ebay to find the block?<br /><br />thanks, rob
coot
Look under Johnson/ Evinrude, on E-bay
Rob DeHaven
thanks for all the help. i need the crossflow so i will keep looking.<br /><br />thanks
Rob DeHaven
bump<br /><br />trying to keep this fresh. hope someone can help.<br /><br />thanks.
mike damron
i have a 77 115 johnson complete motor that runs like a new one 135 psi on each cyl.just put new water pump in ,complete waterpump not a kit. will take 2000 for motor and guarantee it
flatsman
Hey , email me at rfutch@alltel.net , we have a strong dealer here and i will ask him if he has one .
Dhadley
OK a block only. That kinda limits things. The 1978 has the late model bolt pattern for the adaptor housing but still uses the crank with the small center main bearing. <br /><br />The 1979's all use the large center main crank.<br /><br />The 1977 115 20" uses the early bolt pattern.<br /><br />The 1977 140 will work - late bolt pattern, small main crank.<br /><br />Any V4 block 1979 and up will work if you use a large center main crank. <br /><br />Tip - if the front half has the lower pan mounts that bolt on, its a block that uses the small center main crank. If the pan mounts are cast in, its a block for the large center main crank.<br /><br />Jack at Superior (800-338-9281) will have one. Give him a shout.<br /><br />Good luck!
Dhadley
BTW - why do you need another block?
