prop interchange
ddzylka
i have a 1956 evinrude 7.5 fleetwin with a two bladed prop which is damaged and should be replaced. is there a three bladed prop avaialble, if so would it be efficient? are there used props available? <br /><br />thanks for the help. dd
Tracy Coleman
Re: prop interchange
ddzylka<br />See your local John-Rude dealer or miwheel.com<br />Backfire ;)
Kenny Bush
Contact West Marine. They (and quite a few others)offer a few aftermarket props. The three blade is the standard of today but back then two blades were. You should be able to find a buffet of good three bladed props to fit your needs.
Admin5
iboats (the site you are posting on) sells Michigan Wheel props along with other quality aftermarket props. Please give them a chance as well.
