Lou C
Thread starter- Joined
- Nov 10, 2002
- 14,635
Ok guys, my Quadrajet acted up again over the past 2 seasons, not running right, I had it all apart, tried to clean it the best I could, but no joy. So I took the Holley out of the garage that I tried a few years ago, the first time I tried it it wouldn't run right (loading up, too rich) so after re-doing the Quadrajet I took it apart, found a few things that didn't look right (loose clutch bolts on the rear metering plate) but never tried it again till now.
So I bolted it up, it runs surprisingly well, the primary mixture screws respond to adjustment as they should, but I can't get it to idle slower than about 670-700 rpm which I think is a bit too high for a dog clutch outdrive. I am wondering if maybe the secondary throttle adjustment screw (that little screw you can only see with the carb off) might need to be adjusted, but from what I can see from looking in the secondary barrels, the secondary throttle plate seems fully closed, I can see there is a small port below them and the transfer slot above them.
Any suggestions from the Holley guys (Scott?) I'd like to get it down to 600 rpm if possible.
You'll all laugh but I also have a brand new Edelbrock 1409 in case this doesn't work out as planned! But it is more work to install, I have to figure out the throttle linkage and I have to fab a bracket to move the big shifter bell crank mount that OMC used on the Cobras up and over about 1.5" for the wider Edelbrock with the side mounted fuel line to fit.
The Holley while some feel it can be more troublesome, is an easier conversion because OMC and Volvo started using this exact carb in 1990 after they quit building Quadrajets.
I have all the OEM parts to make it work (throttle cable mount, adapter, metal fuel line, etc).
Thoughts?
Thoughts?
