cameron92
- Jun 18, 2026
- 65
Not bad ideally you want a warmed up engine & throttle wide open, I think they’d be higher then. Next leak down test and what did the air pressure test show? If all is good test your manifolds & try running it again. See if you still get water in the oil. Air pressure test is really the most important
The air pressure test is losing psi somewhere. I cant hear anything, smoke test didn't reveal anything. Thought maybe I could hear something in the valve cover but hard to say. I think it might be my setup, it is just a rubber ball that inflates and if I pump more then 12 psi it shoots out of the hose
