cooling water
forelanne
Johnson 175----on the hose, is it normal for water to exit from above lower unit where exhaust housing attaches to motor bracket. There is a cover with 4 bolts on both sides of motor that has a rubber bushing in it--water is exiting forward of that location---normal?<br /><br />------------------
forelanne
Re: cooling water
Am I being Blackballed ??-----HELLO anyone!!<br /><br />------------------
clanton
Re: cooling water
Do you have overheating problem? Some engines do some dont, I have seen some 2000/01 look like more water came from the gearcase seam then went thru the block.
forelanne
Re: cooling water
Yes no water pressure-----impeller ok---Thermo's ok
