Johnson Motor
Paul
My friend has three motors that the casing does not give a clue as to their size.We would like to find out approx. age, and size and if parts can be gotten for them and possibly books for mixture of gas and type of lubricants for the bottom assembly.<br /><br />The first has a lever to take out of gear and the only numbers found on the motor are stamped in the block. Seems to run very well and would like to keep that way. ser 851658<br /> mod TN 26<br /><br />The second is the same appearant size but without the out of gear lever. Does not appear to have a water pump but haven't checked real close. ser 541891<br /> mod HD 25<br /><br />The third is much smaller with no lever. Does not appear to have a water pump but haven't checked real close. ser 680628<br /> mod TD 20
Paul
Re: Johnson Motor
Originally posted by corm:<br />what color?
<br /><br />All three of the motors are kind of a drab green. thanks for the reply hope that you can be of some help.<br /><br />Paul
Eelsid
Re: Johnson Motor
Model TN-26 is a 50-51 5 hp, HD-25 is 46-50 2.5 hp, and TD-20 is a 46-49 5 hp. Found this information at kencook.com, where you can get owners, parts, and service manuals.
Paul
Re: Johnson Motor
Originally posted by Eelsid:<br />Model TN-26 is a 50-51 5 hp, HD-25 is 46-50 2.5 hp, and TD-20 is a 46-49 5 hp. Found this information at kencook.com, where you can get owners, parts, and service manuals.
<br /><br />Thank you for your time and I certinly appreciate you information.<br /><br />paul
corm
Re: Johnson Motor
The HD-25 is probably a 1950 2.5HP Johnson.<br />The TN-26 is about a 1950 5HP Johnson.<br />The TD-20 sounds like a Johnson also.<br />Try here to get more info;<br /> http://www.aomci.org/ <br />You can email a member so you don't have to<br />join the Club.<br />...cool motors...corm
corm
Re: Johnson Motor
I needed to refresh the page I guess.hehe<br />Glad to see Eelsid hooked you up with Ken.<br />I didn't know they were on the web.<br />...have fun...corm
Bear
Re: Johnson Motor
Roy Williams is digging up some old posts everywhere :(
Re: Johnson Motor
To<br />Roy Williams <br />First Mate <br />Member # 17423 <br /><br />I will check with the guy who owns it to see if he is interested in selling.<br /><br />Paul
