Re: Way overpowered??!!
Hi Ted, some of the problems with the old Johnson V4's are:<br />1. Hydro Electric drive gets clogged if left for long periods without use. (I just fixed mine.) see my posts on the subject if you get this problem, I am also putting all info I can get online about it to help others.)<br />2. Powerpacks on the newer units can die from dry solder joints or whatever, expensive to replace, cheaper to swap to points and a car coil, which apparently works very well.<br /><br />They are the two problems I had with mine.<br /><br />Everyone I spoke to over here said the Johnson V4's were fantastic engines that ran forever with good maintenance..<br /><br />My proceedure for painting the leg and cover (essentially everything bar the powerhead)<br />was this.<br />1. circular wire brush in drill machine, get rid of all loose paint. REALLY well.<br />2. sand down as many raised old paint edges as you can with emery.<br />2. ETCH primer, apparently this is important I am told, it must be ETCH primer.<br />3. sand again to get rid of irregularities caused by old paint.<br />4. another code of etch primer and more sanding.<br />5. Several coats of ACRYLIC LACQUER.<br /><br />I went to a boat place, and looked at the OMC and oftermarket paint for outboards, they were both 35 dollar cans of white acrylic lacquer.<br /><br />So I went to the hardware shop down the road, and bought 4 cans of Anchor lacquer, at 9 bucks each,, its the same stuff, or as close as not the matter.<br /><br />so I got 4 cans for the price of one.. and I used all four cans, (in fact I am gettin a 5th tomorrow to keep for touch ups.<br /><br />I choose apliance white.. that way no matter what brand you get, its the same color. (after all, your fridge can only be one shade of white.)<br /><br />looks fantastic I might add, the finish came out looking like new, you wouldn't think for a minute that this is a 30 year old outboard.<br /><br />Anyway, you should keep your motor I think, it will provide for you well if you look after it.. some of the guys I had look at mine (outboad mechs mostly) really loved the old V4's.<br /><br />remember, the maximium horsepower of any 2 stroke engine is at around 5000-5500 rpm, or near the redline.<br /><br />if you never go over 4500 or thereabouts, you will be in your boats recommended power range.. (maybe a governer or something could stop you going over?) <br /><br />I had keeping engines near redline for any length of time. so I doubt I'll ever have a problem.. <br /><br />Its why I love V8 engins, you can sit at 60mph and be doing around 2000 rpm (in a car I mean) whereas my girlfriends Suzuki Serria is sitting on 4500rpm to do the same thing..<br /><br />rgds<br /><br />Frank
