reseal water impeller
joejoe
what do i use to reseal the water pump impellar with. no gaskets in that area. on 1970 4 hp evinrude. thx Joe
JB
Re: reseal water impeller
No gaskets are used down there, Joe. If you completely dismantled the gearcase, there are some seals to reinstall, but if you only replaced the impeller simply reassemble the parts you took out. Be sure that the impeller is "folded" in the right direction and lubed with a bit of soap (I use dishwashing liquid).<br /><br />Good luck.<br />Red sky at night. . .<br />JB :)
joejoe
Thx JB, I just changed the impeller, it looks like somebody before me had also used like a sealant rtv type glue to reattach things is this necessary? thx Joe
joejoe
How can i make sure i install the water impeeler the correct way the other was so badly chewed up that i cant tell what direction the fingers go. thx Joe
JB
Don't replace the previously used sealant.<br /><br />Look at the direction that the starter turns the crankshaft and driveshaft (usually CW, looking down the shaft) the arms should trail the hub.<br /><br />Good luck.<br /><br />Red sky at night. . . <br />JB :)
ka3wld
Joe, we've installed two impellars this past summer for the first time(don't ask :) . At first we thought it was the wrong size because it was so much larger than the housing. Then we (I) came up with the hose clamp idea. Use a large hose clamp to encase the lubed impellar then turn each fin so it will drag behind as it would in a clockwise turn. Our manual said to turn the crankshaft clockwise. Then bring down the housing just to cover the top bent tips of the impellar inside. Once the top of the impellar is inside the housing, release the hose clamp and quickly push the rest of the housing to cover it. Good Luck :) <br />wa3ipb's Wifey :)
joejoe
Thanx for the suggestions. I will give it a whirl in the A.M. Thx Joe
joejoe
JB when you say trail the hub does that meen turn in the same direction of the shaft clockwise? thx Joe
JB
When the hub (and driveshaft) turns, the tips of the arms follow behind the base of the arms.<br /><br />Good luck, Joe.<br />Red sky at night. . . <br />JB :)
joejoe
Thank-you JB<br />I think i got it right. is there a way to tell if i installed it correctly after it is running in water tank? thank-you so much <br />Joe
JB
If you did it backwards, Joe, it will fail within seconds or correct itself. Unfortunately, the former is more likely.<br /><br />Good luck.<br />Red sky at night. . . <br />JB :)
joejoe
JB when you say that it will fail within seconds what are you referring to ?. Water is just spitting out of the exhaust not really a steady stream at all. The motor is still running like crap. runs a few minutes and shuts itself down. and then it will not restart until the motor has cooled down. Some body else is having the same problem on the board so i will watch that thread and see what happens next. Thx
