FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
does anyone have a schematic for the 88hp johnson with a vro tank. How reliable is the vro and There is no warning buzzer on my <br />boat for the vro, is it needed even if you put a little oil in your gas anyway. Sorry for allthe questions.
Some love the vro and some dont. I personally like to disconnect them and run 50:1 mix so their is no powerhead failure due to lack of oil. Are you shure you dont have the warning horn or is it just broken?? Its part of the VRO system.<br /><br />What kind of schematic do you want? One of the VRO system?
The horn is in one of two places..In the remote control (shifter) or under the dash in the accessory wiring. If you get a "beeping" horn you have a low oil condition (under 1/4 tank). If you get a continuous horn its an overheat condition.<br />You need to check to make sure the horn is working. Find the overheat sensors mounted in the block (should have two wires). Disconnect where its joined and turn the key on and ground the wire to the block..The horn should sound.
