1967 johnson 55hp
G DANE
Re: 1967 johnson 55hp
Hey alcan<br /><br />I think you have two problems. Number one is charchin coils touching the magnetos. This causes probably no other problems than the heat. The other problem must be a fuel delivery problem. When the engine dies, try to spray WD 40 into the carbureator, and see if it fires. If it does, it is a fuel problem, otherwise it must be ignition.
clanton
I have an OMC troubleshooting manual for all of the battery powered CDI systems, 15 pages with wiring diagrams, I can mail a copy to Schematic and he can put it in his files and post it. Scanner not working, so it might take 2 weeks.
alcan
Hey Clanton. You were right my motor is a 1968 TRL-10R. Ser# J2978216.The oem manual I am using is for 1969 55hp evinrude triumph. Same motor. Sorry Guys, I'm an analog man in a digital world. Today I tested the charging system acording to the book.Rectifier good,stator ok also. My meter read .8 and .9 between the the yellow leads,the book calls for .75 ohms + - .2. Checked all venting, clear.So I fired it up. As usual it lit right off, sat there an idled for an hour and a half,did'nt miss a beat. Cover on,cover off.Nothing is rubbing under the fly wheel.The fly temp was just warm, same as rest of motor. I could touch it w/bare hands any where,normal. I also checked voltage at the batt. it was 12.45 volts. Clanton that imformation would be great. Thank you. My test tank is good for motors up to 25 to 35 hp. I use a home made (portable) tank and ear muffs for any thing larger. As I don't have any test wheels,I must trailer to boat ramp for high speed testing.I realized this system dosen't use condensers.I'll WOT test and see if I can reproduce symtoms on the trailer. Thanks again. Happy new year.
I had the same proplem well 2 things really 1 coils touching the magnetos & seem to put it out of time, 2 Start at you gas tank & work your way to the carb . Best I can do hope it helps
clanton
Alcan,<br /> Send e-mail,addy to clanton@atlantic.net, I have scanner working, and will try to e-mail to you, 3 pages, 2 pages instructions and 1 page diagram, you should scan for virus before you open page.
alcan
Hey Clanton<br />I did recive your imformation. Thank you very much. I'll let you know how I make out.
hi alan i have a couple things to check one pull sparkplugs after running for a few minnutes and see if their is any water on or around them check all of them for poss.powerhead crack also check and see if your input and water output -squirter is operating pro[perly sometimes not haveing proper water flow whit high speed will cause to overheat u can also do a compresson check to ellimanate your problems hope that helps
ratracer
After more than 6 1/2 years I'm sure he either managed to find and fix the problem or he loosened the motor up and let it fall off into the drink :D
