1974 Evinrude 85HP V4 shifting noise
zj-jeepster
my 1974 V4 Evinrude 85HP is working well now except when shifting into either forward or reverse it makes noises until fully engaged. it goes "gala gala klunk" then everything is smooth. it actuall shakes a bit when it "klunks" then all is well. fluid old or hardware problem? thanks.
JasonB
Re: 1974 Evinrude 85HP V4 shifting noise
I would change the fluid as these motors have an oil pump that helps the shift. My 76 cleared up some noise this way when I first got it.
papasage
donot ease the shifter in gear . push in gear quick.
zj-jeepster
thanks guys,<br /><br />it's docked at the marina now so I'll have to haul it out and take a closer look at the fluid condition.<br /><br />yeh, I've read some where that it should be shifted briskly. I'm not aware of my shifting habbits so I'll check on that too.<br /><br />will try to post back on results, hopefully within a couple weeks.
