Mystic Mariner
- May 7, 2023
- 22
Hello, new to the forum; I have a '91 Johnson 45hp commercial pull start motor. I pulled the plugs and opened the throttle to full. I hooked up a compression tester and get 30lbs on the top cylinder and about 90lbs on the bottom. I pulled it about 5 times and read the gauge. Should I be getting higher readings like an electric start? Motor runs, but now I'm freaking out with these readings. Any help would be appreciated.
