jnelsonusmc
Thread starter- Joined
- Jan 18, 2023
- 41
Hello, I have a 2011 Mercruiser 3.0 inboard that kicked off a code 3050 Catalyst 1 Inactive FMI: 1 Data valid but below normal Occurrences: 1 and engine went into Guardian Protection with a previous fault code of 521009 Merc Fault 9 FMI 31 Not Available. The 3050 is active code and the 521009 is listed under previously active trouble code list. I am running the Diacom diagnostic ver 3.3.6 I bought the Diacom package after local marine mechanic charged me over 4k and boat still does not run right. Boat starts right up, idles and runs good put it in the water under load and right at 1500 to 1800 rpm engine goes into guardian protection mode within 2 mins. I installed New distributor cap and wires, New start switch, New starter relay, New plugs, thermostat; Fuel pump and Water pump; marine mechanic installed New O2 sensors and New TP sensor. All OEM parts used. Boat had been sitting for a while when I bought it reason for the items I replaced. Took it out and engine went into Guardian Protection mode after 2 mins of running at 2500 rpm so took it into local mercruiser marine mechanic who replaced the O2 and TP sensors.
Engine has 200 hours on it
PCM-09
Mercruiser 3.0 MPI 135 A1
Drive Number 1A277619
Codes 3050 and 521009
Diacom ver 3.3.6
Is the O2 loop supposed to be closed?
Bank 1 O2 Loop Status............................ CLOSED
Engine Air Inlet Pressure.......................... 17.7 inHg
Bank 1 CAT Intake O2 %............................ -12.0
Barometric Pressure................................ 29.8 inHg
Bank 1 CAT Outlet O2 %............................ -12.0
Bank 2 O2 Loop Status............................ CLOSED
Bank 2 CAT Intake O2 %............................. 21.0
Bank 2 CAT Outlet O2 %....................... 21.0
Needless to say after a 4,500 bill from the marine mechanic and engine is still not running correctly, I am hoping that someone in the forum can help me fix this myself. I am not a marine mechanic but have above average mechanical abilities and hopeful with help from the forum and the Diacom diagnostic I can get this thing running right. Any assistance would be greatly appreciated.
Regards,
Jim Nelson
PCM-09
Diacom ver 3.3.6
Regards,
Jim Nelson
