Re: David I found what you sought
Realgun, thank you for this research. It however does not prohibit soldering. It also does not stipulate solderless crimp-on connectors. This has been my position ever since this debate started.<br /><br />And I realize that this info is for an automobile and not a boat, but to support my position that soldering is sound method of connecting two wires, here is an instruction sheet from Chrysler Corporation Service & Parts Division for a connector & terminal assembly. Instrucxtion sheet K6853037, supplied with a connector purchased 7/18/05, <br />1. Disconnect battery.<br />2. Disconnect the wiring connector fromits mating half.<br />3. Cut off the existing wiring connector...<br />4. Stagger cut all wires...<br />5. Strip insulation off...<br />6. Stagger cut matching wires on th erepair wire assy...<br />7. Slide a piece of heat shrink tubing onto each wire of the repair harness.<br />8.Connect wire harness end to the repair wire end by twisting(mechanical connection) ends together.<br />9. Solder twisted(mechanical connection) wire ends with rosin core solder.<br />10. Slide heat shrink tubing to cover each splice. Be careful to center each splice inside the tubing. Heat tubing to shrink and seal splice. Use the approved air heat gun only. (Very important to use air heat gun to shrink tubing.)<br />11. Re-tape wire harness over splices...<br />12. Connect wiring connector...<br />13. Reconnect battery.<br />14. Test system.<br /><br />So you see this procedure meets the requirements of ABYC 11.16.3.7. You have the twisted wires as a mechanical means of connection. Merely sliding them together and giving a light twist will not do, but done properly the twist will provide satisfactory mechanical connection with the solder providing another and a sound electrical connection. The heat shrink tubing then seals the connection from the elements.<br /><br />Even though this instruction sheet was provided by Chrysler for road-going automobiles, you can see that the procedure would satisfy ABYC standards too. This is NOT to say that crimped terminals are not a satisfactory connection method however. Done properly either method would provide suitable service. But the keyword here is properly.<br /><br />This has been my position all along.<br /><br />Thank you again for your efforts in providing the information I asked for regarding the standards applying to wiring connection and terminations. And thank you for the time to present my information too.
