Re: Electric System
A few thoughts:<br /><br />(1) Do some reading. You need to estimate your max current draw to appropriately size the inverter. Youre probably looking at something in around the 2.5kw (or +) size. Start here, with the inverter, and work backward from there. Also consider the invert type, modified sine wave vs true sine wave. Powerboat Reports did an evaluation of 6 inverters (1.8 2.6kw) last April. Let me know and Ill post a summery. More on inverters below.<br /><br />(2) Youll need a house battery bank to support the inverter. If you will be doing this frequently, higher-end batteries are a better value. They cost more initially, but last longer, resulting a greater return for the dollar. It is possible to do what you are thinking of without the need for generator/genset if you have a big enough house bank.<br /><br />(3) Alternator: getting a bigger and/or second alternator (100amps or +) allows you dump a lot of power back into the house bank in a short time by running your boats engine. This can make up the difference of kw/hrs that are needed for that 3-day weekend.<br /><br />(4) You also might want to consider this:
http://www.meps.com I like this idea but I would have to get creative with pulley sizes between the jack extension on the engine and the generator to get the required 4500rmps at ideal. Also, theyre not cheap!<br /><br />(5) Also know that starting Jan this year, the EU, the EPA, and the IMO (Intl Maritime Org) are looking at controlling genset emissions. Dont know if/when changes will come down the line, what they are looking to accomplish, and how (if?) it will impact existing gensets. My understanding is better combustion was already mandated and implemented in some gensets, so you may want to research this before buying.<br /><br />(6) Note: you can/should be running house lights off your house bank battery, not the inverter. You get better return for dc discharge with dc house lights. Also consider replacing existing 12vdc (24vdc) incandescent house lamps/bulbs with newer LED bulbs that use a lot less energy, and will likely outlive you
get them on ebay.<br /><br />(1.5) Definitely start by figuring out what size inverter you will need based on the anticipated max ac current you will need at any given time. Most inverter also function as a battery charger for the house battery bank, too. Some inverters have power sharing technology that allows any incoming ac to go to the house on demand; the rest of the ac (if any) goes into charging the house battery bank.<br /><br />Edit: Oh, and welcome to the board!
<br /><br />Do you set in at Avalon or Two Harbours or ?<br /><br />Btw, most marine refrigerators run on ac if available, otherwise they take dc from the house bank.
