cddetelich
Thread starter- Joined
- Oct 7, 2004
- 99
I would like to install a guage to let me know my alternator is charging properly. Which should I install-ammeter or voltmeter? Proper way to install?
Technically, you'd want to install a voltmeter for either reading. It's much safer to install a shunt and then read the voltage across the shunt to obtain current magnitude and direction, rather than run high current carrying wires up to a convenient gauge.<br /><br />That method yields the most information but IMO, it's six of one, half dozen of the other. The simple voltmeter showing bus voltage is sufficient for the vast majority of applications and it's much less costly than the alternative.Originally posted by cddetelich:<br /> I would like to install a guage to let me know my alternator is charging properly. Which should I install-ammeter or voltmeter? Proper way to install?
17.7 volts is an awfully high charge voltage. I would worry about cooking the battery.Your battery if charging should read 14 - 17.7 volts.
