What is the best wat to cut hole in console?
HeadHunt
I will be installing an Icom 402 VHF in my center console. I am planning on flush mounting it. I have the template for the hole cutout size. What is the best method for cutting the hole without chipping? Should I use a jig saw with fine tooth blade? High speed or low speed?<br /><br />Thanks
JB
Re: What is the best wat to cut hole in console?
Put masking tape on the places to be cut.<br /><br />Start with a hole saw.<br /><br />Use a fine tooth blade at low speed.<br /><br />Good luck. :)
CalicoKid
If you use a jigsaw use a very high quality blade, like Bosch, made for laminates. Cover the enire area to be cut with a layer of masking tape first. I'd personally run the saw at medium-high speed and use very light pressure advancing the cut to get a nice smooth opening.<br /><br />If the hole is round a hole saw would work well.<br /><br />Obviously, you want to be very careful of anything behind the console while cutting.
swist
More specifically cover anything that any part of the base of the saw will touch - don't forget when you turn corners the back of the saw will swing away from the cut line. A vibrating saw body against unprotected gelcoat will mar the surface in no time.<br /><br />(Been there, done that :( )
HeadHunt
Thanks very much. Of course, being a VHF, this will be a rectangular hole but I will start with a hole saw to get it going, correct?
Scaaty
Originally posted by HeadHunt:<br /> , this will be a rectangular hole but I will start with a hole saw to get it going, correct?
Skip the hole saw if a rectangle and drill holes (big enough for the sawblade) INSIDE the rectangle at the corners, and saw from there
jimmythekid
dremel or rotozips work well
jheron
Here is a tip from an old sparky if any are interested... when using a hole saw on laminates or other "chippy" surfaces just run the saw in reverse untill your through the first layer and your chipping will be gone :)
