Bszakaly97
Thread starter- Joined
- Jun 23, 2021
- 24
Hello new here so I’ll do my best to explain everything and hopefully I’m in the right place, I have a mercruiser 3.0 in a 99 sea ray 180. Just swapped in a new motor with points... hooked up main harness plug and motor only starts and runs with key engaged. 12v at coil when starter is engaged but with just key on have nothing. When hit wire to + side of coil runs great. Tried replacing ignition simply because I had one round that I knew worked and didn’t change anything. Gauges work along with everything on the dash, also should mentioned I jumped pin 5 &6 on engine harness plug and had constant power to coil.. only used the test light but nothing lights up under the ignition so should I be following purple wire all the way back to main plug? Also already bypassed KS thanks for any help in advanced. Also using a deep cycle battery if that matters... just bought the boat so I also do not know it it worked properly with last motor but the motor in it now I had running and idling fine in last boat with no problems
