motorguide or minkota 52,55 lb
skeeterboy
I am thinking about getting rid of or selling my min kota 28 lb and getting either a MG 52 for 329 or the MK 55lb for 369$, Just wondering if i step up to the bigger lbs will that suck more juice out of my deep cycle and which would be better to buy for the money for a 16ft bass boat. Thanks!
D
DJ
Guest
Re: motorguide or minkota 52,55 lb
I always liked Minn Kota.<br /><br />Yes, it's gonna draw more juice. If you get the MK with the "maximizer" it will surprise you how long thwe battery lasts.
raymondmoyer
Yep gonna suck a little more juice. But as Mr. DJ said the maximizer circutry in MK works wonders. I use a autopilot 55 on 14' tracker sportsman with casting deck, outboard, my fat butt and a friend weighing in around 700 lbs total. I can fish all day on one battery and still have power left over for manuevering when I get back to the ramp. Most of my fishing is done in rivers so I'm fighting current all day too. :)
Copespitter
For your boat I would get a MK 74# Maxxum. I have a 65# on a 15' Gregor aluminum boat thats converted into an aluminum bassboat. The # thrust is just about right. With 74#'s of thrust you will have power to stay in the wind, run up currents, mulch weeds and chase fish boils.<br />Anything above 55# thrust is 24 volts. Any trolling motor that has variable speed (1-10 not a 5 speed) has the maximizer built in.<br />With the maximizer and 24 volts you will have enough juice to last for a couple days.<br />A 74# thrust MK costs around $600. I bought mine used for $300. You can also search the net for reconditioned trolling motors and might be able to find one for around $400.<br />The trolling motor is the most important piece of equipment on the boat so get the biggest and best that you can affor or else you will be upgrading later.
skeeterboy
Another thing will a new minkota fit in the same place as the old one or do i have to drill new holes for the mount to fit??? <br /><br />thanks for the info but i really dont want to go to the 24V system. gotta buy another battery then i have to spend 600 for a new TM and thats a little much for me.
skeeterboy
scrap that idea i think im going to go shead and buy a new 90hp to replace my 50hp i have now that is an 85.
cmuggs
what kind of skeeter do you own skeeter boy
