Prop Blowout
Dirty Worm
Can anyone explain what Prop Blow out is and how to correct the problem?
Bob_VT
Re: Prop Blowout
When the prop runs out of water to pull through. It will sound like you have hit nuetral at wide open throttle. It can be caused by improper engine height or improper trim and sometimes by a prop too small for the load. Hard turns make it happen too.<br /><br />Explain your boat/motor set up and we will try to help.<br /><br />Bob
Bob_VT
Re: Prop Blowout
Yes it would. If you are suspecting a spun hub scratch or mark reference points on the prop and the hub nut assembly. If it is spun you will see it moved.<br /><br />Bob
Bob_VT
Re: Prop Blowout
oopps double post<br />Bob
ThomWV
Re: Prop Blowout
Usually with a spun hub you don't really have to mark much of anything. Just go out and try to bring the engine speed up to over about 2,000 RPM with out it breaking loose.<br /><br />I immagine what you are talking about is plain old everyday ventilation. A lot of folks call it cavitation, but that's not he right term. Cavitation is a condition in which very small bubbles form on the propeller blades because of extremely low pressure and their collapse errodes the metal of the blades. Ventilation is quite different. When one blows out from ventilation what is happening is that the pressure in front of the blades is so low that it will allow surface air to be drawn down to it. Outboard props move water very well but they are terrible in air, so because it can't get a bite in the airiated water it slips like crazy and the engine RPM's soar. Just backing off the throtle for a moment corrects it and you will probably not even fall off plane if you catch it quick. The cause of ventilation is simply to high an engine mounting. Of course some props hold on better than others too, and that is why you can get away with running a 4-blade higher than a 3-blade.<br /><br />Thom
