What Fish Finder Do You Have?
ThomWV
I'm curious, what fish finder, and which transducer, do you have on your boat(s)?<br /><br />I'll Start,<br /><br />Furuno 582L with Airmar M260 1 kW in hull<br /><br />Thom
Mod4
Re: What Fish Finder Do You Have?
Thom, if you do a search you will see a multitude of topics related to fish finders.
pee wee
Garmin 240, transom mount speed & temp transducer.
trollhole
Mod4. That was not the question he asked. I think it is a good question and valid.<br /><br />Lowrance LCX15-mt with GPS and Hotspots. 50-200 dual :D
mikecjn
Humminbird Piranha 5 with temp sensor. Works pretty well. I just wish the screen was a bit larger.
jtexas
Hey Thom, how about we add a couple words about how satisfied we are with it?<br /><br />Humminbird Piranah 3 - it's cheap & serviceable, but I wouldn't recommend it strongly; it's really more like a child's toy than a grown man's. :)
ThomWV
That's a good idea. Acutally I was just wondering what the distribution would look like. I expected to see a lot of Lowrance, quite a few Garmin, Furuno's of course, and others.<br /><br />As for ours, it suits us very well, but its not for everyone. Its really a combination aimed at deep water performance and most folks don't need that. Our use is primarily hunting Tuna and Marlin in water between 100~500 fathoms.<br /><br />Thom
Ralph 123
Garmin Bluesea 160 - it works great. Seems to be very accurate. Includes water temp. Nice clear, big graphics. Fool proof to use.
RICKRICK1
Ensign
Humminbird Wide eye two of them one transom and one at trolling motor. Very satisfied with performance.
Trent
Si-Tex CVS-106 MKII. Great little color sounder.
Franki
Hummingbird Wide 100, piece of junk.. but well built housing.. no amount of relocation and differing angles will get the transducer to work at anything much above no wake speeds...<br /><br />but like I said, the housing is solid.. gonna sell it and get a Navman I think.. you get more for your money.<br /><br />rgds<br /><br />Franki
gbader
Franki<br /><br />I have the Navman gear - Fish 4500 and the Tracker 5500 (with WA maps :) )<br /><br />Not bad units, I lose the sounder above 20 knots but that is probably my transducer setup<br /><br />Overall, very happy and the colour screens are great.<br /><br />cheers<br /><br />greg
snapperbait
My 21' has a Furuno LS6100/airmar thru hull transducer.. Very happy with it...<br /><br />My 15' has a Humminbird wide portrait/transom mount transducer... Happy with it as well..
dingbat
Si-Tex CVS-106. It's now going on 12 years old and I can't kill it.
18rabbit
Primary fishfinder/sounder: Simrad<br />Watts: 2x1000 (8000 wpp)<br />Transducer: Airmar – model ??? (16-in x 5.4-in / 16-lbs.) pocket mounted.<br />Freq: 38kHz / 200kHz<br /><br />Shallow water (no ff) sounder: Furuno RD-30<br />Watts: 200<br />Transducer: Airmar B-17 thru-hull mounted.<br />Freq: 235kHz
lund17
primary is an Eagle Tri-finder on the console for trolling and locating fish/bait/structure. So far it does what I need. In the bow a humminbird that was free and is worth every penny. The 'bird is only used for depth and thats all it's worth hence the free part.
waterinthefuel
Lowrance X-4. Proud to have fewer pixels per square inch than they did on the CRT's in Apollo 14! LOL
rickdb1boat
I have to say that I really don't understand the problem with himminbirds locking on at speed. Never had that problem on either boats I run. Maybe I just got lucky. I also have no problem seeing arches when going slower(200 DX). This has been with 3 different humminbird unit over the years. I can see my lure below the boat! I also have an Eagle which perform well too. Can't speak for others, just my experience..
rickdb1boat
I have to say that I really don't understand the problem with humminbirds locking on at speed. Never had that problem on either boats I run. Maybe I'm lucky! I also have no problem seeing arches when going slower(200 DX). This has been with 3 different humminbird unit over the years. I can see my lure below the boat, bottom locks on a depths up to 100' and everything inbetween. I'm not gonna change, unless it lets me down. Transducer angle is important on these units,(Maybe more so) as they are on other units to get proper readings. Once I had that right, all was well. I also have an Eagle which perform well too. Can't speak for others, just my experience..
