- Jul 23, 2011
- 52,294
if you buy a pre-made spec built stroker, it will have cast pistons with 4-relief cuts. basically stock GM pistons. you leave a lot of power on the table (about 40-50hp) when you do that vs picking the proper pistons to work with vortec heads (LCQ style)
cost of a new 6.2 base motor is about $4700-$5300 depending on where you get it (their prices also went up from the beginning of the year)
the pre-made 377 or 383 motors are about 350hp at the crank or 320hp at the prop.
6.2L - 383 c.i. "Stroker" Base Marine Engine
www.michiganmotorz.com
