dumb questions, real easy answer...
phatmanmike
which is it....<br />epoxy will stick to "polyester"resin but resin wont stick to epoxy...<br />or resin will stick to epoxy but epoxy wont stick to resin..<br /><br />i searched for this but only got confused...its early<br /><br />m ikey
JB
Re: dumb questions, real easy answer...
Both epoxy and polyester are resins.<br /><br />I have never had a problem bonding one to the other.
ED21
Master Chief Petty Officer
Polyester isn't the adhesive that epoxy is.<br />When putting anything on epoxy, even more epoxy be sure to wash off or sand off the amine blush(whatever that is) that comes to the surface of epoxy when it cures.
ThomWV
One of the characteristics of epoxy is that it sets to a very hard smooth surface. Actually nothing will bond to it all that well unless its been at least scrubbed off a little bit. The amine blush is some chemical that forms on the surface when it sets, it will come off with soap and water allowing a chemical bond, but you should still go for the roughened surface for the mechanical bond. Epoxy will certainly bond to Polyester, which is what I think you meant when you said simply resin. They are both resin's, Polyester and Epoxy. They have different characteristics other than their bonding ability and epoxy is about 4x expensive. I think its worth it, I don't use anything else any more.<br /><br />Thom
KRS
Banned
All the stitch-n-glue books I read state that poly is good for poly, epoxy is good for epoxy and poly. So, only mix if you step-up to epoxy, don't put polyester on an epoxy.<br /><br />Good luck!
ED21
I just came across a short article by someone at System Three Resins who said that chemicals in the epoxy inhibit the curing of polyester resins.<br />So Azfyrfyter seems to have hit the nail on the head.
