dlogvine
Master Chief Petty Officer
Thread starter- Joined
- May 4, 2015
- 839
Draining oil on my v8 5.0 1998 Mercruiser is a pain in the neck, since the pump I bought pumps it so slowly that it takes at least an hour to suck 5+ quarts of oil. Reaching the bottom and opening the oil drain plug is also problematic since I have to take apart at least parts of the separating panels in an engine compartment, which I did last time during the oil change. So I found an EZ plug that has a valve and attached hose that allows to drain oil immediately by opening valve and threading the hose through the boat water drain hole. My question is if anybody used it and which brand do you recommend, they come in several varieties. Thank you. Any advice is greatly appreciated
