chartersj
Thread starter- Joined
- May 14, 2013
- 305
I recently put the motor back in my boat and having a hard time getting it to roll over. The motor has a relay for the starter and not a starter slave solenoid. I have power from the battery to the starter, but no power to the starter solenoid when I turn the key to start. I have power to the starter relay (red/purple), I get good continuity from yellow/red at the key to the relay. I have checked through the neutral safety switch at the gear shifter and shift cable at the motor. I crossed the terminals at the relay and starter would roll the motor. I swapped relays with the fuel pump relay and get the same symptoms. I do not get a click or sound of any kind when I turn the key from on to start to try to roll the motor over. Lanyard is on as well. Looking for advise on what to check next. Thanks.
