No crank no start please help
1dumbazz
Hello everyone
I just got my first bass boat and I don’t know anything
about outboards that being said here is my situation
i bought this boat that has been siting for a couple of years it has a 150 evinrude I hooked up a fully charged battery and I am not getting any power anywhere not even the tilt the only place my test light turns on is the solenoid the positive cable is hooked up to any ideas What can I check or how to diagnose
Crosbyman
this could be a long write up…. have you considered taking it in a shop for a look at by an experienced mechanic...before buying it ? .
some…...things to do or look for
good compression test and equal
carb job for certain
gearcase inspection and new oil
any fuses ….blown
all connections need to ne looked at cleaned and secured
fuel tank may be all crudded needs cleaning
fuel hose may need replacement
etc... etc... utube is your friend but get yourself a service manual by the way what year is it and model
1dumbazz
I forgot to mention no power to the ignition switch either
1dumbazz
It is a 1990 Bayliner Cobra center console bass/ski boat with a 150 evinrude
Vic.S
But what year is the outboard ? Also 1990?
and what is its model number ? That 's the important info. Always quote it when asking for help or buying parts
Somewhere associated with the main motor cable assembly there is a fuse ( 20 amp ??? )
Find it, check it ................ it has probably blown
On the boatinfo website you will find a manual that covers your engine but an official manufacturers manual will be a zillion times better
http://www.boatinfo.no/lib/library.html
https://www.outboardbooks.com/
F_R
I agree, fuse. However, always make sure the battery and cables are not the problem. Juice cannot get through loose or corroded battery cable connections. I'd call it the #1 electrical problem on boats.
1dumbazz
I think the motor is a 2001
E150FPXSIF
thats the number plate
1dumbazz
How I Acquired the boat is a friend of a friend where about to get Evicted and needed a loan he couldn’t pay me back so he gave me the boat I felt bad for him so I took the deal he had no knowledge of the past history his uncle passed and left it to him that’s all I know about it
anyways I am going to check the fuses and cables
when I get back my mom was rushed to the ER
mill get back to you thanks for all the advice
GA_Boater
Before spending a nickle on this boat, get it in your name with legal paperwork if you didn't get any from the friend of a friend with the dead uncle. You may not an easy time getting it in your name, so that's the first step.
Take care of Mom first.
Vic.S
E150FPXSIF
There are 7x10amp fuses in the power distribution panel plus 2 spare ones and a gadget for extracting them.
#35. #71 and #72 in this diagram
convert
1dumbazz
I just got back home and I am going to check those fuses in the morning thank you for the Diagram
and I will check the ground thank you all for your advice I will keep you posted
1dumbazz
It was just a fuse thank you sooo much
its cranking now but still no spark
the coils look pretty Corroded so I think I’ll start by replacing them and going from there
