mikemlittle
Thread starter- Joined
- Jul 8, 2018
- 25
My FIL gave us a 1989 Maxum Force 125. I replaced the battery, ignition switch, fuel lines, spark plugs, and tried to get it to start. The motor turns over but doesn't start. I know it's getting fuel because the carbs are leaking a bit (sat for 7 years and most likely needs gaskets). Is there anything else I should be considering since the motor won't start? The motor looks good for the most part and fuel lines & carbs look very clean. There is something wonky with the wiring.. I think.. unless force outboards were wired to the battery like this. Also, the dash has a placard that says safety lanyard must be attached to the driver. Currently it isn't attached to anything. Could this be a reason it won't start?
