cheburashka
Thread starter- Joined
- May 28, 2005
- 715
I just used a Sierra kit to rebuild a Rochester 2GC two-barrel. The engine runs much better, and the original bogging problem seems to be solved when I'm running on muffs, but I'm still not getting much fuel out of the throttle pump. I cleaned it up and smoothed out the walls, so it should be working properly. I also noticed that in the instructions for the kit and in Seloc, there's a reference to an aluminum check ball that sits in the pump well. This carb didn't have one when I took it apart so I assumed it didn't need one. Was I wrong? How can you tell if it needs the check ball? <br /><br />Second question--the fuel filter had no spring behind it when I pulled it out. Should this carb have a spring that keeps tension on the filter and presses it against the inlet?<br /><br />Thanks for all the advice.
